good afternoon, I just downloaded light burn latest version and have change the setting of my xcarve 1000 ( 30 and 32) however the lasers stops mid way thru a job.
any help is welcomed.
thanks,
thanks,
Does it say anything in the console when this happens? Usually this is the result of a USB disconnection.
I disabled the usb auto power in windows. I do have a 33 ft cable for the xcontroller. Nothing else on the console. It just stops.
USB is spec’d for 16ft, max. If you have a longer cable, you might need an active / repeater cable for that to work correctly.
