Pause job between layers
Hi
I have a Laser with manual Z axis, Is their any way to pause the job when the layers change so I can manually tweak the Z axis
Thanks
Mark
you could export the gcode and add the pause yourself or another option could be to add a layer with a very slow movement and power so low it doesn’t mark.
options for gcode to insert is M6/tool change and G4/dwell. Check to see if LightBurn support the M6 tool change command. Gcode senders will pause the job and prompt you for hitting enter to continue.
