This is my first posting. I hope that it’s in the correct place.
Hi,
I am a relative Newbie and following a steep learning curve.
I had a 15W laser built for me in the UK, and I have found it is based on a Chinese 3018 machine.
Supplied without instructions the fan on the diode housing packed up overheated and damaged the laser.
This has now been replaced, but I am wary of overheating the unit again.
I have had a temperature sensor fitted to the outside of the diode housing which I am able to monitor.
I had to re-install the GRBL, and have as follows:
Grbl 1.1h [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
ok
[MSG:Caution: Unlocked]
ok
$0=3
$1=25
$2=0
$3=5
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=80.164
$101=80.164
$102=250.000
$110=25000.000
$111=25000.000
$112=500.000
$120=5000.000
$121=2000.000
$122=10.000
$130=550.000
$131=330.000
$132=200.000
ok
As you can see, I am using the latest Grbl 1.1h, with the latest Lightburn version on a windows 10 Laptop dedicated for the laser.
My Problem.
Not wishing to overheat the diode again, I have been pausing the cut when a temperature of 30 deg C is reached.
Since the last upgrade the Pause/Resume button has been very temperamental, often not resuming after a 5 minute rest.
I notice from other conversations that screen savers have been mentioned, mine is off.
Can anyone suggest what I can do to restore the Pause/Resume button, and also what the temperature of the outside of the laser diode unit should run at.
Many thanks in advance
