I just updated Lightburn, and after, went to cut design. it should have taken 20 minutes, it took 34, cause the machine kept pausing. it was not firing while paused, but it would cut, pause, start cutting again, pause, on and on. then would cut a full section. It seems it may have something to do with pausing at power change??? was something changed with the upgrade that i need to check? Please help
I notice this and am clueless on what’s happening.
Does the timer on the bottom of the Ruida screen keep running when it’s paused?
The only way I know of to pause these is via the console.
Do you use send or start?
Is the connection usb or Ethernet?
Do you mind posting your .lbrn2 file, so we can take a look at it… I doubt it’s with your file, but I’m at pretty much of a loss on what to advise.
