Pesky vectors greyed out
Hi all. Up until now i havent had an issue with nodes or vectors not closing. I normally export problematic files from lightburn into Vectric Aspire, as i find it easier to fix in Aspire…but this ones got me beat. I cant resize tabs/slots, Looking at it you can see it has greyed out areas, ive closed any open vectors, checked there are no any extra nodes, no out of alignment measurements… dont know what else to do other than hand it to you guys. File is attached.
problematic disc.lbrn2 (59.6 KB)
…interesting what the experts say, to me your file looks very suspicious, it won’t/can’t open in LB either.
That’s true, this looks suspicious…
Dont know what happened there… i cant open it either…so heres the original file. This one opens fine.
take 2.lbrn2 (46.0 KB)
It’s all open shapes. This was a simple fix. Select All, Auto Join Selected shapes.
take 2.lbrn2 (37.9 KB)
That looks like a DXF file wearing a lbrn2 extension.
Change it to DXF and it imports cleanly:
Surprisingly, the geometry seems well-formed, with no open shapes at all.
now try resizing the 4 diagonal slots in the middle. yes it was an easy fix to close the shapes but like i said im my original post that isnt the problem i have
No problem. Not sure why it isn’t working for you. I was able to resize both directions.
Here is a cleaner SVG. The DXF had a lot of short line segments in the perimeter.
Disc
