placeholder text
I’m having a problem with engraving: when I apply a fill to the text, it engraves well for the first few seconds, but then the engraving starts to fade—this only happens with filled text.
Post an image of what you see.
I am just a beginner; I’ve only owned the laser for a short time and am still learning how to use it. This is the result I’m getting using an optic rated for a 200x200mm field (marked f=290mm 290D15141). Number 1 is in the center of the work area using bidirectional fill; for number 2, I also added cross-hatching. Number 3 is in the top-left corner of the work area with bidirectional fill, and number 4 is in the same spot but with added cross-hatching. I apologize in advance for my English; I am from the Czech Republic and am using Google Translate.
I do not have a fiber laser, but I am sure the plane of the lens is not perfectly parallel with the base, or material support. I believe fiber laser focus is very critical.
And your Google English is just fine.
Okay, I’ll try reaching out to someone with more experience with this specific laser and its optics. So, I can likely rule out a software error, and a fault in the laser source is also improbable; that leaves a likely issue with the optical lens settings—since, with this laser, every lens has its own file that must be loaded. Unfortunately, as I said, I’m a complete amateur, and I don’t want to tinker with it when I don’t fully understand it—I’d hate to make things even worse.
That is probably the best tool in your toolbox.
If you do not get some attention soon, do another post and I will try dropping a few names. :grin:
