Playing with Basswood with 5 watt UV
Here’s the Facebook page of the maker:
https://www.facebook.com/alex.ribikk
I tried posting a link to one of the videos a couple of days ago, but the forum site said my post needed review. Last night it was still waiting for review, so I deleted that post and posted the version above without the link. Let’s see if this one gets hung up for review or not.
The link you posted is interesting in the huge variety of metal they claim to have colored, but I think most of their work was on silver. Quote from the article:
“Here, we report a widely applicable high-throughput and deterministic process for producing a comprehensive angle-independent (that is, non-iridescent) colour palette composed of many colours via ps laser nonburst and burst colouring methods. This is achieved on unpolished metal surfaces, including silver, gold, copper and aluminium, and surfaces with frosting and centimetre-scale topographic features. We demonstrate the process by colouring silver coins produced at the Royal Canadian Mint, including large 5 kg coins.”
It’s very interesting to me that those examples are all on silver except the last one which is on gold. Large 5kg silver coins!
@markjern
In my laser FB “Den of Lasers” a member with 60 watt MOPA did this on brass
That’s totally cool. Nice work, give’em a pat on the back for us. :+1:
:grinning_cat:
@jkwilborn
Best I could do
to much time and wasted coins
Boy those look great, makes it difficult to even duplicate. I can imagine the time and money to reach this level with coins.
I think everyone looks forward to your next post.
Thanks for spreading your knowledge.. we can all use some.
:grinning_cat:
Thank you for sharing this, Nicky! These are beautiful!
I have a 60w MOPA laser somewhere in transit from Haotian in China. I have some brass coins and am hoping these settings might get me in the right ballpark for my own brass coloring adventures. I did find settings to mark brown on brass coins with my xTool F1, but I didn’t get multiple colors.
About how long did these take in the laser?
Did you do all the layers at once or take a break in between layers?
Did you somehow hold the coins in position in the laser or just set them there?
How hot did the coins get when you did these?
Nicky, I was a little slow on the uptake, but I just realized that this is almost certainly dithered! That’s awesome!! I just applied to join that group and plan to reach out to that person to see if they want to compare notes. It looks like they’re coloring brass in a very similar way to how I hope to color stainless and titanium. :+1: Thank you very much for this lead!
@markjern
My coin.business card etc jig
Old heat sink from an old project
I use a plum to adjust focus distance
Like the plum bob idea.. :thinking:
:grinning_cat:
@jkwilborn
Old school ..quick and east
especially when focusing at bottom of a cup
I posted in a few groups and they all laughed at it
Then, I guess the jokes on them… :grinning_face:
People seem to be missing out when it come to using simple instruments. Although, they’ve been using them for centuries. I guess most of them have never heard of the KISS principle.
Thanks for stirring up the little gray cells. :thinking:
:grinning_cat:
@markjern Thanks mate
check your FB PM,s
@Bulldog This is fascinating and super helpful! Thank you!
It looks like managing the temperature of the coins is important (heat sink and fan). Claude and I came up with a weird approach of heating a large aluninum sheet (3/4" x 12" x 12") to 50 degrees C so it will cool from the ambient temperature air the ventilation pulls past it. The idea is that the ambient cooling will remove heat faster than the laser adds it, so thermostatic control of the heating pad will just heat it less while the laser is active, an the metal will stay at 50 degrees continually. Propylene glycol under the sheet is supposed to make good thermal contact with the aluminum slab. We’ll see how it works in practice.
I spent a lot of time last night with the drill press and tapping holes for the support to raise, level, and position the slab over another sheet that will serve as a base. I’m still winging it on some aspects of the design. I’ll share pictures if I get it to actually work.
I too really appreciate your use of the plumb bob for focus! :+1:
Thank you for the FB pointer and for getting me in that group!
@markjern
Most welcome
as for cooling/temp control
couple years Back
I ordered several Peltier modules
was going to make a 6x 6 inch cooling pad with temp control with variable speed control fan
4 units I calculated would do the job using 12 VDC ps at 25 amps
(in my past life this would be easy peasy )
Then design a controller
Then lost interest
@Bulldog
I thought about cooling the slab using an ice water circulation system like I do for the anodizing bath, but then I realized that would condense unless I insulated it and sealed it from the air. Your peltier module sounds much better because the modules might stay warm enough to not condense. My current plan is to use a 3D printer heating pad with an Inkbird fish tank thermostat to elevate the aluminum slab’s temperature and keep it within a few degrees of 50 C so radiant cooling and heat transfer to the flowing air overwhelms the heat gain from the laser. If this works, it means the temperature stays at the set point and the heating pad just runs less when the laser is also heating the slab. If the heat loss isn’t enough, I can add heat sinks and/or more air circulation.
I used another Inkbird to control the temperature in my lab more precisely than the cheap oil filled electric heater would do on its own (heater is just on, Inkbird sensor is near the anodizing bath). My bath temperature control didn’t have heating because ambient was warmer than the bath set point in the summer. But when the ambient temperature went lower than the set point, I didn’t have a way to reach set point. My low brow room heating system keeps ambient just a touch above the bath’s set point, so the ice water cooling system has almost no work to do to reach the set point. And my space is at a comfy temperature.
I’m pretty sure I will need very consistent metal temperature if I’m going to have a chance of getting consistent colors a dot at a time using direct laser oxidation. I’m eager to get the laser and go down the rabbit hole!
Sometimes, if you scan on an angle like 45 that helps also.
