I have installed an tried using the lightburn software but I keep getting an alarm, after homing.
<Alarm|WPos:2147483.648,-2147483.648,2147483.648|FS:0,-8|Pn:P|Ov:0,52,193>
I am new at this so not sure what to do.
Are you using the ortur laser master 2 Pro? If so, are you using it in a sunny or bright place? The sun triggers the sensor and sets the alarm off. I only know because I had this problem. Hope this helps.
There should be more text to your alarm message, I think.
It’s probably not homing properly.
Sorry. If your in a sunny place it will keep triggering the alarm try in a dark area. On OLM2 pro it does anyway.
So I came home and tried with light out, still not working any suggestions?
Try this: In the console, type the command:
G10 L2 P1 X0 Y0
(and press enter)
Then, power the machine off, move the laser head to the front-left position, and power back up again.
