Plugin for optimization settings
Hello,
I would like to know if the LightBurn developers are considering integrating plugins specifically for the “Optimization Settings” tab in the Laser panel.
My specific idea is to be able to select a plugin that could automatically optimize cutting paths for materials like metal sheets. This optimization would be based on user parameters (e.g., sheet thickness, metal type, laser power) or default settings.
The goal is to make the software more professional for metal cutting, eliminating the need for manual adjustment of layer order, cut sequencing, or other complex edits required to prevent overburn and thermal deformation in critical areas. A potential plugin could:
  • Intelligently set the cutting order (inner/outer, direction, etc.).
  • Analyze geometry and dynamically adjust parameters (e.g., speed, power) in corners or small details to avoid overburn.
Furthermore, I am personally very interested in developing such a plugin myself. Is there any consideration for opening this section up for third-party extensions? This would allow the community to develop tools for specific professional applications, such as metal cutting.
Thank you for your time and for the excellent software!
An external plugin system has been considered, but is not available at this time. Id encourage anyone thinking about adding dev features to LightBurn to keep an eye on our Jobs listings here Jobs - LightBurn Software Forum
