PNG work great svg does not
Hi I’m using a creality falcon 10 watt laser engraver and updated lightburn. If I make an image in photo shop, save as a PNG, my laser cuts and engraves perfect. Circles are circles, square are squares.
If I import a svg or create something in lightburn, circles look like lemon and square aren’t square.
Calibrated asis x asis is spot on, y asis is not.
If I make a square 5 inches by 5 inches, x is 5inches but y asis is 4.85
No matter what I do y asis doesn’t move.
If my box is 5 x 5 in a PNG file it’s fine.
Tia
Perhaps Edit → Settings → File Settings → SVG Import Settings is … uh … set to 96 DPI, rather than 72 DPI:
That will affect imported SVG files, not PNG files.
That suggests a mechanical problem, rather than a file import problem.
As a first step in debugging, scale this test pattern to fit the platform and run it as fast as it will go, in Line mode with optimizations turned off and power set to mark cardboard:
GrundTest.lbrn2
Any distortion in the results on the cardboard indicates a mechanical problem.
