Pointer offset problems
I have my pointer offset enableled and have added an offset measurment, but it seams the offset it not working. I have other machines using same version of LB and they work great…
What could be wrong? any suggestions?
Here’s how i set mine
Draw a small box like 150 mm x 150 mm
Set the laser power to like 15%, just enough trace the box
Run the job to trace the box.
Next use the Red Offset Pointe to position the laser
on the bottom left corner of the box you traced
Then run the job again
The second box should trace exactly over the first one
If not adjust the pointer offset and do again
Second way to do this:
Set the laser power to very low, just enough to see
Use a metric ruler and measure the x and y offset between the blue laser and the offset pointer
Enter the values into Laser Offset in Lightburn.
Run a small box job and see if offset is correct
You may have to do this a couple of times
Here’s a video on a different method
@baricl1317 , Thanks for the reply, Since I have used the pointer on my other machines I do know how to set up and use the offset. But on another machine that I just added the pointer to, it will not offset even though I have it enabledI have rebooted PC and Lightburn.
