This is my setup in LB:
as you can see the item to be but is on the top left, but when I start the burn the actual cuts are around here:
I also tried to use the position tool, but that too positions the cutter at the wrong place
What kind of laser do you have, what controller does it use, and does it have homing or limit switches? The âYour Machineâ section in your profile just says, âChinese 15wâ which doesnât provide any sort of useful detail.
Updated my profile
I have a 50w co2 (china) laser, I think this is it
http://cuttingengravinglaser.com/en/50w-co2-usb-laser-engraving-and-cutting-machine-rotary-axis-bring-your-own.htm
It looks like youâre using âUser Originâ or âCurrent Positionâ as the âStart Fromâ setting. They donât place the art on the laser where it is on the screen - âAbsolute Coordsâ mode does that. Read here:
https://lightburnsoftware.github.io/NewDocs/CoordinatesOrigin.html
