I ́ve been using Lightburn for a while with a jtech attached to a X-Carve using the first controller generation. Everything was working fine until I upgraded to the X-Controller, where the laser is engraving in the wrong coordinates in the Y Axis (X axis is right) using absolute coords. For example, the work should be done in Y pos 107.000 and it ́s engraving in Y pos 378.000. As I mentioned before, X pos are right. If I move the Y axis “manually” using lightburn, the distance travelled are right.
What could be the problem? If I use actual position for starting the work, I have no problems with distances, the issue is using absolute coordinates.
My G54 shows [G54:2.000,-488.000,-23.700]. I also checked the $10 and it´s set to 0, but the machine is still starting the job way far in the Y axis. What could the problem be? thanks!
