Laser position goes too far into the corner of the frame and continues causing the gears to slip over the drive belts. Sculpfun 10
Does this happen when you try to home it?
Sculpfun S10 has no limit switches. So you need to care about the starting position and the size of your projects. Go through this guide: Coordinate systems & workpiece alignment – Diode Laser Wiki
By starting up
Vielen Dank!!
