Just recently I have started having an interesting issue where the relative positioning between objects will change depending on which computer I open the file on. I primarily do the design work on an M2 MacBook Air and have a Dell ThinClient running Windows 10 connected to the laser. It’s often just shifting things by a few MM at most, and does not happen on all files. I have confirmed that all of the Fonts I use are installed on both systems and that the origin is the same, as is the workbed size. I’m guess this has to do with font rendering as so far I have only noticed with text being re-positioned but it’s not consistent.
Interesting
Would there be any chance you confirm if both files are in lbrn2 format or LBRN?
and will it happen on most or all files, or just some with heavy use of fonts?
Lastly maybe you could export as SVG or AI on each, and upload the exports, we would have a solid comparative to check
they are lbrn2 files, the files are maybe half font and half paths based on object count. I’ll run exports on both systems and compare.
