In the Material Library, I had a one-layer material definition for Aluminum that I had deleted in LB a long time ago. Accordingly, it does not show up in LB. But when I look at the .clb file using NotePad++, it still shows the entry as if I had not deleted it. Everything else looks fine. Should I just use NotePad++ to delete this entry, or does it serve another purpose? Did I do something wrong that caused this?
