Potencia 10w es demasiado para materiales plasticos SCULPFUN iCube10W
Tenemos el laser de 10w, y nos produce que maduras en los materiales plasticos, ¿es posible adquirir? el cabezal de 3w? y que sea intercambiable?
We have the 10w laser, and it causes burns on plastic materials, is it possible to purchase the 3w head? and that it is interchangeable?
English:
Without knowing which specific machine you are talking about, I would say yes, for sure. It is advisable that it meets the same specifications in terms of connections and drilling holes for fixing.
Español:
Sin saber de qué máquina en concreto estás hablando, diría que sí, seguro. Se recomienda que cumpla con las mismas especificaciones en cuanto a conexiones y orificios de fijación.
Es la SCULPFUN iCube 10W
English:
You’re absolutely right, sorry. I didn’t read the “subject” carefully and limited myself to the topic. :blush: :blush:
But in principle it’s like I said.
The best thing is to consult sculpfun support, who will respond there so that you don’t have any doubts.
Español:
Tienes toda la razón, lo siento. Fui yo quien no leyó atentamente el “Sujeto” y me limité al tema. :blush: :blush:
Pero en principio es como dije.
Lo mejor es consultar al soporte de sculpfun, quienes allí te responderán para que no tengas dudas.
You can exchange the iCube laser heads, though the 10W heads needs a different power connector. But the heads are not sold separately yet, I think.
In general, you can also use it with plastics (if that’s your question), but lasering plastics is dangerous in most cases and not really advisable.
You can set the 10w to 1 watt by entering 10% in the Power Max (%) box of the Cuts/Layers window. There is no need to buy a lower power laser. My 10w laser will give a visible light at 0.25%, but will not burn anything.
Read this line until you understand what it means. The words TOXIC FUMES applies here.
