Since upgrading to the latest Lightburn version I have had a recurring problem. My laser is an Emblaser 2.
When working on any project in the latest Lightburn version I have noticed when I switch back and forth from mm to inches and back to mm (not totally fluent in metric) to gauge the overall size of my work area frame, the support height reverts back to 2 mm even though I had it set for 27.1 mm prior to the quick switch over to inches. This has lead to head crashes into the work surface. This reverting back to a default support height when switching measurement systems (mm-in-mm) has been repeatable on dozens of project I have made in the last week. Even when I save the project work, close it out, re-open it with the correct values all showing, just changing the measurement system will cause the support value to be changed back to a default value of 2 mm.
I’ll gladly demonstrate this via a Zoom call if you need to see it happen real time.
I have attached three photos numbered 1, 2, 3. The first one is where everything is set correctly. The second one the only thing I have changed is toggled from mm to inches. The third one I just toggled back to mm from inches.
Note the support number has changed, and I have never touched it. Since moving to the latest version of Lightburn, this bug has been consistent no matter what project file I have opened/created.
Apparently I can’t attach a pdf file which has all three photos annotated. Can I send it under separate cover, email, or something like that. It was easier to annotate a document than the photos.
