Power/ frecuency output wont change when Marc
Hi
When I run the laser to mark a tumbler i use 900speed and 100 power, then when i change and assign the library to clean at 1500v and 30 power it change son the full option but wont change on the output so laser marks as before 900 speed and 100 power, i need to turn off my laser source and turn on again and change are now applied, what could it be the problem, runs on MacBook Pro os Catalina
If you can show this and supply the project file, you should send it to support…
What you are explaining, shouldn’t occur.
Will contact support
