Power issue straight after update
Hi all. Had a issue this morning straight after i updated to 2.1.01 i have story boards for all my materials i use, 3mm mdf has always cut cleanly at 400mm min and 37.5 % power. After this update im up to 45% and i have to push parts out that normally fell out at less power on previous lightburn versions. Is there something im missing like a setting somewhere that may have changed ? I did check that mm per min was still checked and not mm per sec but that was fine. Cut test was performed on the same piece of mdf. Top image shows cut test on a previous version of lightburn, and the bottom on 2.1.01 Laser is a Creality falcon2 pro 40 watt diode. And im using the same air supply and pressure that ive always used: 17cfm industrial compressor instead of the crappy choofer creality supply. any help greatly appreciated.
I have the same problem , no cutting ability reduce on a 150 and a 100 watt
I also had camera problems. New layout is confusing when it comes to recalibrating. Ive uninstalled and gone back to an earlier version of lightburn. Both Problems solved, think ill hold off on updating till the bugs are sorted.
This looks like a double posting. There are comments in the other posting that are relevant. Is it a “bug” or just a change in settings?
