Thanks for the quick responses.
I have an Elegoo Phecda 20W unit.
Using Lightburn Test Grid with the computer connected to the unit, I get the expected Test Grid results, as follows:
Laser power changes as expected; low power engraves, and as the power gets higher, the cuts get deeper until the grid squares are correctly cut out, and the entire workpiece is cut out of the plywood.
I save the G-code to a file, which appears to have the appropriate instructions to adjust the power:
; LightBurn 1.5.06
; GRBL device profile, absolute coords
; Bounds: X156.72 Y146.52 to X243.28 Y253.48
G00 G17 G40 G21 G54
G90
M4
; Cut @ 400 mm/sec, 20% power
M8
G0 X182.777Y248.019
; Layer
G1 Y248.753S200F24000
G1 X182.294
G1 Y249.057
G1 X183.07
G1 Y247.883
G1 X182.89Y247.75
G1 X182.692Y247.653
G1 X182.479Y247.595
; Cut @ 100 mm/sec, 50% power
M8
G0 X175.276Y164.429
; Layer
G1 X170.276S500F6000
G1 Y169.429
G1 X175.276
G1 Y164.429
; Cut @ 100 mm/sec, 55% power
M8
G0 X181.776Y164.429
; Layer
G1 X176.776S550
G1 Y169.429
G1 X181.776
G1 Y164.429
I tell Lightburn to burn that file, expecting the same results. However, when burning from the file, the power settings in the G-code don’t have any effect, and all I get is a low power engraving.
As you can see from the G-code, successive grid squares have different Sxxx values, which have no apparent effect.
from other posts on the forum, I suspect the unit has defaulted to a maximum power setting, and needs a command to reset the maximum allowed power,
Switching the unit off and back on doesn’t help.
Thanks again.
