So I am working with the Power Scale option and am running into an issue I think. So I am trying to create an Engraving Power/Speed Test where I have 10 Rows by 10 Columns and I have my max speed on the spectrum at 350 mm/s and the max power at 95%.
The issue I am running into is that when I run the file, 10% Power at 350 mm/s is coming out really dark.
Am I not using the Power Scale Right? My Layer Settings for example are Speed: 350 mm/s, 100% Power Max, 50% Min, and .07 LPI.
Sorry for so many replies but I also just remembered my issue a few days ago, you have to set a minimum on your color for that speed. Whatever you minimum to get the tube to fire. I have my mine set to 9 and the max to 100%, and my power scale goes from 10% to 95%.
