Power seems way too high
How is Ruida controller connected to the laser PSU? CN5 is the block having the laser PSU output:
Are you connected using PWM or L-AN1? If your laser PSU is connected via PWM, then the PSU may no be converting the PWM properly. Have you made any adjustments to the frequency settings? You should confirm the frequency is set to 20kHz:
