Power/Speed Update bug?
When i’m running a job and decide I need to increase the speed, say using the increase 1% or increase 10% feature it increases both the speed and power at the same time by the same amount. I’m sure it didn’t use to and it doesn’t happen if i use the increase power feature rather than speed.
Windows 10 - Current version of LightBurn GCode version
This isn’t a bug - it’s how the GRBL controller handles variable power. If you speed up the laser, it automatically increases the power output to compensate for the higher speed, and this is handled by the controller itself, not LightBurn - we’re just showing the numbers.
ok thank you. I’m sure it didn’t used to but I have just changed from a K40 MiniGrbl to a Ortur LM2
