Not sure what is going on. I noticed my lightburn did some changes now with power set on 2% it is showing about 16ma on the gauge. Normally it should be at about 7ma.
it has been quite awhile since I had any problems or had to make any adjustments to my GRBL settings and I dont remember .
Is this a CO2 machine? Your bio only lists a diode machine.
Sorry, yes it is a CO2 machine
If you’re running grbl, both machine and software need to know the ‘spindle speed’ as this controls the laser. Lightburn needs to know the S-Value Max setting and the machine needs to know it too. Usually this is the $30 value. Lightburn defaults to 1000, if your machines $30 value is 256, any power setting over 25% will likely product full power.
At 2% power, a glass tube co2 won’t usually lase.
Suggest you check both of these…
Good luck.
Thanks for your reply, Yes my $30= was at 1000.
I don’t know how, exactly your grbl board controls the laser. There are two basic ways.
A console pot is wired across ground and 5+, to allow the user to set the maximum tube current. Then the pwm drives the enable line. If the active lines setup, on my controller it goes low to enable.
The other way is to wire L through a switch to ground. Disabling this ground line disables the lps.
Then the pwm goes directly into the IN input of the lps.
Do you have a voltmeter?
Verify the speed units have not changed from whatever you used before to something different due to the new link between Design and Control units:
If you previously used mm/s and it’s now running with the same numeric values in mm/min, that’ll overcook everything.
I am running a Monport control board. There is a pot on the panel. I am unsure how it is wired.
Yes I have a volt meter… I appreciate any help.
Let me think about this a few. There are only two controls, IN and L, I don’t have a K40 type, so I’m not that familiar with the lps or just power supply on these. Mine has and L input, which is enabled low. Mine also has an H input with the inverted effect, so high is enabled.
You can check both for the pwm being correct or the L/H input, whatever it uses. Most pwm is right side up, meaning that a 70% pwm, inverted is a 30% pwm..
