Is it possible for me to change the duration of the test fire pulse time?
I want to do a power test series using the same amount of time with different amounts of energy. I know I could draw lines to this, but prefer a point penetration.
For example, 20% power with 1 sec, 30% with 1 sec. and so on
You can’t do single points with LightBurn, however if you enable Cut Through mode with a power and duration, and set the layer power to zero, and drew short lines, the start of each line would fire a dot, but the rest would not fire.
thank you very much, i will try your suggestion
