Pre-computed paths?
Hi, would it be possible to save the computed paths?
I am using 2 computers:
  1. One is fairly decent on which I do the designs and is able to compute offset fills and everyhing in decent time.
  2. The other one is ancient laptop in the garage directly connected to the laser on which I controll the machine.
The old computer struggles computing again the paths before starting the job. The other computer coud do it so faster.
If you have the S10 as stated in your profile, you can save the gcode on the powerful machine and use a simple gcode sender on the laser machine. You don’t need LB on that PC at all then.
Oh, cool! Thanks, I didn’t know that. I will try it next time.
…and yes, I still have the S10.
