I have an object selected, unlocked, and expected to be able to type in an exact number from the origin to locate the object in the x direction, but LB won’t take what I type. Also, how do I change the object green sq location? I want it to be in the exact center of the object. For some reason, it is in the upper left corner.
If you select an object, the x, y location should allow you to enter a number and move the object…
This is the job origin.
I knew it was something like the job origin you pointed to but couldn’t find it and it was right there all the time! I was looking to far into the weeds. Thanks, Jack!
