PreRelease 2.2 RC-2 and Before - Menu Item Is Mislabeled
This has been around for a while, so it’s not a bug or something new. just something that has been mislabeled.
In the import menu you’ll find a listing called image files. The proper name for the type of files listed would be Raster Files (bmp .jpg .jpeg .png .gif .tiff .tga .webp).
An image file can be either a vector and a raster file
Correct me if I am wrong, but I thought all these listed were image formats using a pixel format? Raster is one type of scan, as well as Sweep, C-scan, and B-scan. Maybe they should technically be called Pixel Files?
That’s correct. I don’t believe that there is any mention of how the images are actually processed. Ie: dithered, rastered or the like. They are generically categorized as " images"
Most CAM/laser tools all use “image” colloquially to mean pixel-based formats, with vector formats (SVG, DXF, AI) broken out separately precisely because they behave so differently on import (traced/pathed vs. rasterized). So LightBurn’s usage isn’t wrong by industry convention, even if it’s not the most pedantically precise term available
