I sent a few test jobs to my Fusion Pro. The laser doesn’t appear to acknowledge or recognize the speed settings from Lightburn. No matter what speed I send, it seems to run at the same speed. I tried 10% speed, 50%, and 100%. The interface on the laser show “???” for the speed for each job I send.
Presumably you are sending the job to your Epilog using the ‘Print (Keep Colors)’. This means only limited job information can be transmitted from LightBurn - like shape geometry and layer colors, Cut Settings like speed and power will have to be applied with the Epilog software.
I believe you can use ‘color mapping’ to make this easier - to map LightBurn layers to preset material settings? - something like this:
@NicholasL we (quietly) added Epilog support in the 2.2 RC-2 !
The speed uses mm/min by default. Were you referring to the Laser Power % instead?
Please also confirm that you selected the correct device type as shown in the “Laser” window here:
I am so used to setting cut parameters for this laser in a percentage format. So I set the speed to 50, which in my head was 50% speed when it was actually 50in/min. Apparently 0.5% speed is below the threshold that the laser will recognize? I set the speed to 992 in/min which is approximately 10% speed, and things worked as expected.
But, if I set the speed to 99.21in/min which should be 1% the laser travel speed is a lot faster than it should be. The laser control screen show ?? for the speed.
In fact, a dev confirmed that this shouldn’t happen in the first place.
As the tooltip for the speed states:
“…tops out at 9,921 in/min. Faster Settings are reduced to that when the job is sent”
Yes, 100in/min is still fast. The laser should recognize this as 1% speed but it doesn’t.
The screen on the laser reads out percentages instead of in/min for speed. The laser is capable of run as low as 1% speed all the way up to 100% speed.
Here’s a couple screen shots of the epilogue dashboard engrave/cut settings from my windows machine. As you can see, speed/power/frequency are all percentages.
