Print and Cut alignment at a CO2 laser with no red dot pointer
For people who use a CO2 laser for print and cut, it can be difficult to jog the machine perfectly over the targets. And if you do not have a red dot laser pointer, using the pulse button can be a pain as it can be difficult to see where the spot is going exactly - particularly if it’s on the edge of where you just burnt a spot.
Consider this print and cut target. It demonstrates an alternative way of setting up the targets but it will only work if you are intending to use the ‘no scaling’ alignment (if the intended physical output size is to match the size in LightBurn).
Notice there are two crosshair targets, and a line. They must be in line with each other. They can can be either vertically or horizontally placed next to your print targets - whichever side is the longest will give the most accurate results.
Once you have jogged the laser to the vicinity of the first target, lower the Speed setting at the control panel so you have fine control over the jog, and reduce the laser pulse power so the burn spot is small/feeble. Jog until a pulse lands a bulls eye at the cross hairs:
I find it helpful to stand and look from the right-hand side of the machine while getting the burn lined up with the horizontal part of the crosshair (using the up and down buttons).
The second crosshair is just a spare in case you burn up the first.
People with a red dot pointer fitted may opt to physically move the material instead to speed up the process with the first target.
After setting the first target, select the line target and use the ‘Jog To Selection’ button which should get you close to the line:
Now jog and pulse the laser until you get the burn right on the line - anywhere on the line, so there is plenty of space to keep trying.
This is the interesting part… the second target for a no-scale alignment does not have to be a perfectly targeted crosshair - only the angle matters.
You can now ‘Align Outputs’ with ‘No Scaling’:
In this example, I sent these four parts to my loose cardboard again using Print and Cut and changed the line to be 1mm on/off perforated. You can see they landed perfectly on the existing shapes:
I’ll have to give this a try…
Thanks…
:grinning_cat:
