Print and Cut alignment totally outside workspace
Trying print and cut, but cut ends outside (lower left) of work area and causes boundary violation.
Turning of soft limits in controller runs job it into hard limits switches as expected, also preview shows print outside. Same cut without print and cut just works fine.
Thanks a lot for your support, Adrian
Finally I have go the solution.
As my Printer uses negative coordinates and Lightburn works with positive I had to implement the following:
  • Tell the Machine to use Offset, by defining a Macro with the following command:
    G10 L2 P1 X-282 Y-217
  • Check the Machine Settings and make sure it reports workspace coordinates under $10
Get Position under Move now reports positive values, which now are correct for Print and cut.
Details can be found under the following link:
https://docs.lightburnsoftware.com/CommonGrblSetups.html#negative-coordinate-machines
