Print and cut error
I’ve been trying to use the print and cut function on a project that I ran before and I am getting an error “You need to set a different target for the second position”. I have moved the laser to the second position in the move tab the coordinates have changed another thing I have noticed that I never saw before is a large red circle appears when I select the first target. Any suggestions?
You’re likely missing a step.
For each target you need to:
  1. select the object in LightBurn
  2. move the laser head using the jogging controls
  3. Laser Tools → Print and Cut → Set ??? Target Position
I’m guessing you’re not doing the first step listed for the second target.
Thanks in advance for the help but I figured it out. I had my targets grouped together. DUH
