Print and Cut Vertical Lines
Good morning,
I’m having an issue with the print and cut feature.
I set it all up using the registration makes and it cuts the shape, however the cut it makes is leaving evenly spaced vertical lines, as per the attached photo.
I can cut the exact file without using the print and cut feature and get a perfect cut.
Changing the power, speed, focus, and air assist but doesn’t help. I’ve restarted the machine several time (unplugged it) along with the computer and updated the software to the latest version and it still doesn’t improve.
I’m using an Omtech Polar, cutting 3mm cast clear acrylic at 6m/s and 55% power.
I have over 100 A4 plaques to cut and I’m hoping to obtain a better finished product.
Can anyone assist?
