JasonG
(Jason G)
October 12, 2026, 12:55am
1
Sometimes Print & Cut works 100% perfect. No issues. Sometimes, with the exact same files I get this .. a progressive “shift” on the Y-Axis from the top of the bed to the bottom of the bed.
I have very precise hash marks that I use to align, and I’m diligent about ensuring that alignment is 100% accurate on both the first and second hashmark.
Any idea what’s happening here?
ednisley
(Ed Nisley)
October 12, 2026, 2:19pm
2
With a Ruida controller, progressive misalignment immediately suggests:
Things to note:
Either axis driver can be incorrect
The problem only occurs with specific patterns
Past performance is no guarantee of future behavior
A (lengthy) previous discussion explores some of the possibilities:
Red-Black 90w Laser
Ruida controller
engrave 400mm/s 25%
Fill 450mm/s 20%
Cut 25mm/s 65%
Birch ply held down pins
belts are tight so are stepper motors
When doing a engrave/fill and cut I get the fill shift while the engrave bunches up, cut out in just fine. This is repeatable, and all come out the same, like it was meant to be, how do I attach image?
Pay attention to / back up the original settings:
Ed, you were right. I’ve checked the backups from earliest to now.
22/11/23 x true y false
13/7/26 changed to true from your advice but I failed to see they were different
16/7/26 changed both to false from Nicholas’ advice.
Today both false - still cutting as it should.
Clearly I have read your initial comment, got giddy reading the x=true and changed the y to match. I never tried both to false until Nicolas told me where I’d gone wrong.
I’ve backed up th…
