I have a GRBL laser machine(cron craft) and with laserGRBL my projects burn perfectly.
When I use the trial lightburn 0.9.24 software then the same projects does not complete - it just stops and I found that it lost connection with the arduino board.
I’ve changed the usb cable twice, disabled the usb selective suspend setting and even tried different pc’s with the same end result.
Even with easel my projects completed 100%.
Can it be a GRBL setup problem or maybe hardware when I connect to lightburn?
