hi all i trying to use a pdf file into lighburn but when i try to charge this is what happent
pdf file
what happent in lightburn
pdf file
yes that is the page that i take the pdf!, so i guess that is way the only thing that appears on lightburn when i import is the 1" square, you know what i can make to be able to import this pickguard and the square into lightburn? thanks
thanks so much that file is perfect! what i was doing was use photoshop, delected the background and convert the shape to a path after save the file as dxf and ready, i have a 40w diode laser, so i think that i will try with that same setting of 3000 sped and 80% power! thanks so much
