Problem editing SVG file with picture as background
Hello, this is probably a question that’s already been asked, but despite my searches, I haven’t found an answer.
Here’s my problem: I generated an SVG file from an image using a Python script. The scipt generates a set of polygons which tries to roughly follow the shapes and colors of the image, but since it’s far from perfect, I need to finalize the tracing in LightBurn before cutting.
So, I imported my image and SVG file into LightBurn, but every time I want to edit a polygon, I have to hide the image if I want to select it. I tried locking the image, but that doesn’t work.
I would probably be able to do it in Inkscape, but I don’t want to learn a new tool and being so used to the LightBurn editor that I’d prefer to use it.
Thanks for reading!
Dominique
PS: I’d be happy to give you my setup, but I don’t think it will change the solution :wink:
  • PC running Windows 11 Pro
  • latest version of LightBurn 2.0.04
  • Sculpfun30GRBL engraver
your problem file itself will be more useful for troubleshooting.
