Problem Elegoo Phecda
Hello, I’m new here. I have an Elegoo Phecda and am having quite a few problems with it. I have several questions: 1. What is the default position? 2. Should the laser head be in the designated home position when I turn on the device? 3. When setting up the Mintion laser camera, the number 4 was engraved in the top left corner instead of the bottom left. What am I doing wrong? 5. Can I connect the Mintion directly to my laptop via the USB port that goes into the power adapter? The reason I’m asking is that my Wi-Fi connection keeps dropping. Some videos mention split-camera setup.
Apparently it has no homing switches so I would position the laser at lower left corner before turning machine on.
Thank you for your reply, I will try it.
ELEGOO Phecda, basic operation manual, v2.pdf
Thank you so much for your help. I wasn’t familiar with this document.
