Problem engraving picture
Hi!
Trying to engrave a picture, but the machine does one line then comes up with error. I’ve tried resetting all the settings and restarted the machine but that’s about as far as my knowledge will take me. I’m getting this error
“error:2
Numeric value format is not valid or missing an expected value.
On or near line 588:”
Job halted"
The easiest way to check is to save this project as gcode and search for line 588 and show what’s in there.
Make sure you didn’t enable gcode clustering in device settings, but if it was, it should have stopped at the first line already, I think.
The problem is that’s not always the same spot. Tried it again and this time i got the error on or near line 95
Clustering is off in settings
Tried it once more and got
“error:20
Unsupported or invalid g-code command found in block.
On or near line 106:”
Got this now:
error:1
G-code words consist of a letter and a value. Letter was not found.
On or near line 364:
Can you upload your file?
I might have found the problem.
Don’t know how many posts I’ve read about the different errors I’ve gotten. In one post it said it could be static on the cable, so their recommendation was to export the G-code and plug it in the control box. Tried that, and that actually seemed to work.
