I have lighburn and i connect my laser via a usb cable.
Cleaned the lens
Cleaned the mirrors
I have done a laser dot test and that seem to work fine
When it comes to cutting with the laser its as if there is not enough power to cut and the speed is stuck at 200. I have a screenshot attached of the laser machine settings.
Purchased under two years ago – works really well and has been upgraded to lightburn with new controller Ruida (I think that makes sense)
I have Smokeandmirrors install a new controller and has been working very well… it is only the last day or it has now not creating enough power to cut… I have to do two passes which I never had to do before.
I have checked mirrors and lens and they seem fine
The link to the machine works, but no photo of settings.
Do you have a mA meter to help determine if the tube is lasing?
Has the mA meter reading changed doing the same job as before?
I always start at the beginning. Post a photo of the beam where it goes into m1 (Mirror 1) so we can see how the beam power distribution looks. Not a ‘burnt’ hole, need to see how the beam… Hoping it’s not anything but TEM0
Since you claim it’s aligned, then this is the best starting place. When these tube start failing, sometimes it’s first noticed by your problem and it not resonating properly.
