I have a Longer Ray 5. The controller is MKS DLC32V2.1, Filmware : V2.20( SM.H35.20230626 ) I’m new at this and have a problem I can’t fix. I keep getting an error 5 when trying to home. I’m using Lightburn software version 1.7.08. Thank You
Is this a new machine? Does this machine have limit switches? Has it ever worked?
It is a new machine, has no limit switches and has never worked.
[/quote]
That’s why you get the error. You cannot home a machine without limit switches. You should place it in the home corner before turning it on. That will establish your 0,0 position.
Thank you ! Should I put limit switches on it or can I run without
You can run without.
Thank you again.
