I have a Boss LS 2440 with RUIDA 644xs. Lightburn 9.22 just installed. Using Boss rotary attachment. I have not run any cups in a while but having a problem with rotating the cup based on its diameter. I have never had any problem in the past, so I am a little surprised. I use the rotary setup feature and use the parameters I have used before. The problem is no matter what value I use for diameter the cup rotates the same distance. I know I have a connection to the laser and can read for it. Any ideas why change I make to the cup diameter in rotary setup have no effect? Is there another setting I may have inadvertently changed that would cause this problem.
Got it figured out…
