Rotary issue on 50w chinese laser with Ruida controller.
I followed the Myers Woodshop video setting it up.
Did the line test successfully.
Then did a 30mm x 30mm box to test out.
Test was successful.
But when i go to engrave my image, it comes up short on the Y axis. Image is supposed to be 107mm but ends up 95mm.
I even went as far as creating a box around the image with the exact same measurements and then only running the box to see if it comes out short.
It comes out perfect.
Then i run the image…and it ends up short. I have no idea what to do.
