Hi there, im kind of new to Laser Engraving, and im strugling with these lines in LightBurn, im not sure where the problem came from, i cant even make circles.
I have the Neje Master 2 Max with N40630.
I already tight the belts and the problem stays the same, anyone can help me out?
Thanks
try to lower acceleration
I did it, the issue is exactly the same if was 3000 speed and 50 speed
and in what axis is the issue? X or Y
I cant find yet, i already untight all the belts and always get worse, then tight one by and in the ent after do all again this issue presists
Since you have checked the belts, wiggle the engraver head and see if anything feels loose.
Also a small set screw or grub screw can be loose in the drive cog. If the problem is getting worse with each cycle a loose fastener may be what you’re looking for.
