Can anyone help me with my problem. I have a fox alien cnc with a laser, my problem is the absolute coord. doesn’t work, every time I try to use it my laser goes all the way to the back right. I would be grateful for any help.
Does the laser Home properly?
Does the Jog buttons work correctly?
If the answer is YES to both questions, then you likely have a machine offset problem. This is common when CNC mill is used with a laser. The Mill is setup to use a different graph quadrant than the Laser. You may find your solution here:
If not, come back and we will play Question & Answer.
