Problem with boolean
Orturlm3 20w,lightburn version 2.1.04 windows 11
No mater what I’ve tried to weld and or use the boolean tools I still can’t get the cross to “cut” the sunflowers. I want it to look like the sunflowers are in back of the cross.
I select the sunflower and hold shift then select the cross and have done it the opposite way yet nothing works. I have only tried to do this with the one sunflower at the upper right but have shown what I want the end result to be with 2 sunflowers behind the cross as if the cross was solid and laying on top of the sunflowers.
Tom
Have you tried using the Cut Shapes tool? Cut Shapes - LightBurn User Guide
How you select them also matters. Try swapping which areas are selected, then do a ^B (brings up the boolean gui). You can see what it’s going to do…
:grinning_cat:
I’ve tried all of the above and I still can’t get it to work.
I’ll try again tomorrow if I have time.
Thanks for the help.
Tom
Upload the file so others can mess with it.
What is the simple/easy way to share the file.
Drag it onto the Reply.
Second simplest it to use that little up arrow thingie icon.
You can just copy the file and paste into your reply.
cross file.lbrn2 (229.7 KB)
I hope this is what you asked for and if not please explain in “vegetable lightburn” language.
Is this what you want?
Yes but I also want to know how you did it??? Please!
I’ll try. I used the cuts/layers to to hide black and blue layer and then grouped the flowers together. Then I ungrouped the cross and used offset to make small offset around cross, selected it and then shift selected the flowers and used weld. Then unhide the layers.
I would also use something like offset fill on your black layer to reduce time.
I don’t know if I did it the same way but we both got it! LOL
Whatever gets it done.
