Problem with creality falcon rotary roller
I’ve been breaking my head with this current problem with creality falcon rotary roller. Laser keeps slamming into the right rail. Rotary setting is on. When I preform testing, it rotates both ways and everything runs smooth, but when I try to burn I get message : cut might be out of bounds- continue anyway? When I click ok, it slams into the right rail and get an alarm which I can only turn it off with the stop button.
Did you follow th Lightburn rotary docs?
Are your Job origin set to Current position?
Also read:
1.Are you using Current Position?
2. Have you opened up the Yaxis travel limit (there is no rotary limit)?
3. Did you rotate the rotary several times so it is in the middle of your Yaxis range?
4. Did you turn off Hard and Soft limits?
I am using current position, ill check 2-4. thank you
