Hi,
I have a problem with the software configuration. If I create a single layer file and run 10 passes at 100% power, everything works fine and I cut the desired material (image 1)
But if I create two layer, 1 with a power to 40% (1 pass) por engrave and a second with the power to 100% (10 pass) for cut, doesn’t works. The layer 1 (engrave) it’s OK, but the layer 2 (cut), doesn’t works. Does not cut the material. Obviously, same material and same machine that image 1.
Any idea? Configuration:
$0=10
$1=25
$2=0
$3=2
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=800.000
$101=800.000
$102=800.000
$110=1000.000
$111=1000.000
$112=600.000
$120=30.000
$121=30.000
$122=30.000
$130=200.000
$131=200.000
$132=200.000
Thanks a lot
