If i engrave a photo then about a minute my laser starts doing this.
Anybody know’s why this happen’s and what is solution. (ruida)
Thanx…
loose belts???
No.
This is happened if i engrave PHOTO ONLY.
What settings are you using for DPI and speed? The most common cause of this on Ruida, aside from losing steps, is the controller getting overloaded because the image is too dense, and requires too much processing speed.
If you press Start, the job is transmitted to the controller while it is running the job. If the job is very dense, the controller can sometimes miss incoming data. Better for photos if you use Send instead of Start, then run the job from the machine panel once the entire file is in the controller.
Problem solved! (last suggestion from Oz)
Thank you!
